Old 23-Dec-2010, 4:06 PM   #11
Chris12
The tripod your are looking at is fine. It says that it does not come with pitch pads. Tripods and pitch pads are also available from sources like SolidSignal.com
John's suggested compass heading is correct. I was reading out of the wrong column of your TVF report. Thank you John for catching that. Start with a level install. You can adjust left / right, up / down and last, slight tilt angles... if necessary.
Thanks for this info. I am looking at an overall height of 3-4' for the tripod/mast combo. The antenna is 20" high so this should be fine, right?
Also, when on the roof adjusting the antenna, what can I use to measure the signal I am getting?
Chris12 is offline   Reply With Quote
