Old 24-Oct-2014, 11:48 AM   #4
timgr
Originally Posted by M.Unit View Post
Thanks so much for responding with the correct link, much appreciated.
By the way, 261 degrees magnetic just means 261 degrees clockwise from N, correct?
It means 261 degrees on a compass. The magnetic pole of the earth is different from the actual pole, and a compass will read slightly different from a map or your GPS(?), for example. Just buy an inexpensive compass and use it to aim your antenna. http://www.amazon.com/Rothco-398-Del...ywords=compass
