Old 23-Oct-2014, 11:40 PM   #1
M.Unit
Question This antenna in the attic? Phoenix metro
I'm reposting this from another forum section, was told I'd get better help here.
Hello everyone.
We cut the cord a few years back and used this antenna mounted on the side of the house (about 9ft from ground) and connected to all 3 tvs and had phenomenal reception. http://www.amazon.com/RCA-ANT751-Dur.../dp/B0024R4B5C
We do live in a large metro area and all of our towers are less than 30 miles away.
We are now moving into a new house, relatively same distance from all the towers (less than 30 miles) and have very little to no obstructions around us. This house actually has a ton of attic space that is easily accessible since we have spray foam insulation. The construction manager mentioned one of our neighbors mounted his "outside-sized" antenna inside his attic and has had no issues.
We are thinking of doing the same thing - mounting inside the attic.....looking at our TV report, do you all think this antenna would suffice or would you recommend something else? I ask only because we left the antenna connected at the old house so we have to purchase a new one any way. And we are looking to mainly get the channels in green....Phoenix areas is fine, dont need channels from Tucson.
http://www.tvfool.com/?option=com_wr...d243fe044d3e47
Thanks again!
M.Unit is offline   Reply With Quote
