Old 23-Oct-2014, 9:21 PM   #7
devidog
Originally Posted by timgr View Post
If you want to mount a dedicated VHF-high antenna, an Antennacraft Y10713 is about the most sensitive you can get without heroic measures. http://www.antennacraft.net/Antennas/AntennasVHF.html
I assume that I need to combine the two antennas on the mast and go down with one wire? I've read on other posts about doing this with the RCA TVPRAMP-1R. Jeez that's a big antenna, 120" ... I'm guessing this would be mounted on the mast pointed at KRCG 5' below the rotor and DB8B.
devidog is offline   Reply With Quote
