Tnx.
One point that I forgot to mention. This same setup was hooked with a CM7778 (medium gain) before and then the reception was worse. A few channels from the 240 direction appeared only after replacing the medium gain with a high gain amplifier.
So, isn't removing the pre-amplifier altogether going to make things much worse?
