Old 23-Oct-2014, 1:11 AM   #2
1. Remove the pre-amp.
2. See step 1.
There is absolutely no need for high-gain amp. Probably no need for the DA either, but it likely won't harm reception.
For initial setup, run a single temporary coax cable straight from the antenna to the TV and test reception. If that works, build one piece at a time back until you have the system put back together without breaking anything.
