Thread: Newb
Old 22-Oct-2014, 2:11 PM   #5
A NM of 60 is more than 1000 times more signal than you ideally need.
Actually, it's a million times more than is required. 60 dB = 6 x 10^6th power when converted from log to linear numbers.
If anything, your amplifier is overloading your TV tuner and it's occasionally breaking up.
Probably. With signals that strong, an amplifier should be avoided.
All you should need is a small UHF-only antenna aimed to the north to catch your local stations.
