thanks timgr I was able to buy a Channel Master CM-4228HD for a decent price locally originally just to run some tests up in the attic and I'm pulling in both VHF stations easily, so I may just keep this model since it wont require a second antenna.
Just an update with the CM-4228 I'm sucessfully recieving all stations up in the attic through a window facing directly north. WFSB was the toughest to pull in but comes in clear at night and a peak signal around 57 on the Panansonic tv signal meter.
The leaves are still on the trees, so imagine with the added bonus of a preamp,being outside facing the antenna local and additional mast height I should be in business with a real clear picture. Going to install the grounding rod this weekend and order the rest of the equipment
Again thanks for the help everyone very much appreciated
Reason: mispell edit
