The tripod your are looking at is fine. It says that it does not come with pitch pads. Tripods and pitch pads are also available from sources like SolidSignal.com
John's suggested compass heading is correct. I was reading out of the wrong column of your TVF report. Thank you John for catching that. Start with a level install. You can adjust left / right, up / down and last, slight tilt angles... if necessary.
