Old 20-Oct-2014, 4:55 AM   #12
ZippyTheChicken
Gees son do you live in a cave lined in lead?
I though I had it bad with a half dozen in 20db half dozen more above 14db but I am a good 55+ miles from the antennas so its flakey... especially during sun up.
you don't have signal ... you have negative signal..
I made my own 4bay and stuck an RCA 22db amp on it but i need something a bit stronger.. I don't think the RCA is really putting out 22db probably 12db.
probably should go with a commercial antenna too but I did get a little help with the design so it should actually be a 10-15db antenna...
I really like when people list their real results about products because it lets other people realize that some of the ratings that might work on a bench in a lab aren't what you get in the real world even if you follow every step perfectly.....
I am actually looking at a 100db distribution amp on ebay direct from china figure its probably 40db actual heh... but still it has a gain dial on it so
Son you give me hope .. you an your black hole of antenna signals .. heh
Originally Posted by Alan909 View Post
Yes it did cost $67...that's why I said in the beginning..."Ok All, go ahead and shoot me now and get it over with, lol"...I had a little money to play with so I tried this preamp...Still going to order the AP2870 PreAmp and the MXU59 antenna tomorrow...and put the 1500321 in my closet for an emergency preamp...For $67, sure don't want to toss it in the trash can, lol...It's still working fine and have all 13 channels from having only 6 channels...a bit weak on 26 and 50 but hope by stacking the MXU59 will cure that and pull in FOX channel 22(66)...Bet my TVFOOL REPORT is the worst anyone have seen, sheesh...
ZippyTheChicken is offline   Reply With Quote
