Old 23-Dec-2010, 7:38 AM   #9
Chris12
Originally Posted by John Candle View Post
Any way I went to the >>Start MAPS<< part of tvfool and put in an antenna height of 15 to 25 feet above ground and the signals are strong. You can do it this way as a test. You can get a tripod roof mount and just set it on the garage roof with the antenna and see what you can receive. It looks like the group of stations to the east north are at 56 degrees magnetic compass.
Will this tripod work fine? http://www.amazon.com/Winegard-SW-00...3089232&sr=8-1
I was wondering if the antenna would come with anything to attach it to the roof.
So I'll try 56* and 68* (groundyourmast recommendation) and see which works better. Should I point the antenna horizontally on my roof toward 56*/68*, or tip it slightly vertical ?
Chris12 is offline   Reply With Quote
