Old 19-Oct-2014, 3:00 PM   #3
sethbob3030
Thanks for the reply Stephanie. Currently the pre-amp is not hooked up, just the drop amp from antennas direct.
The A-B switch would be the simplest solition, but not a feasible one with everyone in the house watching seperate shows at the same time that seem to require both antennas, even though they are "multi-directional", it seems they still need pointed.
What I need to know is what I need to make both antennas work simultaneously, and at optimum performance.
What equipment is needed to make this happen? How should everything be connected? Would anything change with how we currently have the antennas mounted? Etc etc etc
sethbob3030 is offline   Reply With Quote
