Old 17-Oct-2014, 7:37 PM   #2
Tower Guy
The predicted signal at 40' is too low for a single Y10-7-13. However, if the transmitted antenna pattern favors you and your terrain is favorable you might be able to find a height that works. You could consider a pair of the same antennas stacked and then expect to find the optimum height by trial and error.
