Old 23-Dec-2010, 2:22 AM   #1
Chris12
Setup advice, I'd like to drop comcast :)
Hello,
I would like to cancel my comcast subscription as I have found myself watching streaming Netflix more often. My only problem is that we have 4 other tv viewers in my home. I'd like to get as many channels as I can, but as you will see in my report I am not in an ideal location. I am also concerned with the look of the antenna as I plan on mounting it on my roof. I also have the option of mounting on top of a garage next to my home, but the garage is about 10-14 feet lower than my roof peak. There are also trees next to the garage, not sure if this matters.
I have cable run to 4 tv's currently. Each tv has an independent rg6 cable, and the splitter is at the corner of my house where the comcast cable comes in. I'm not sure what type of splitter is currently in place, but comcast I installed it and may take it back when I cancel.
Here are my results **http://www.tvfool.com/?option=com_wr...da32492d411bbe
The garage top mount would probably be the easiest, would you guys recommend it? What type of antenna and amp would you recommend?
Any help would be greatly appreciated.
Best Regards,
Chris
Chris12 is offline   Reply With Quote
