so I finally got a chance to put in the homemade antenna, and I am more than shocked at the reception I am getting on most of the channels. I thank you all for your help, and have one last question. So I know that if I use an amplifier with the one antenna I have now I will most likely lose some of the closer stations. I am wondering what would happen if I had two antennas one with a amplifier and one with out, would I still lose the closer stations? Would it fix the skipping that is on one or two channels? The two antennas would be hooked up to the same tv through the cable. thanks again
