1. Can you please post the model of the 'amplified horizontal v antenna'? No one can really evaluate it properly without knowing exactly what it is. Or post a photo if you don't know. Also what direction on a compass is it aimed at?
2. Your signals are already pretty strong. Have you tried bypassing the amplifier? [Not just unplugging it, but removing both it and it's power source.]
3. Have you checked all your connections? Have you tried testing with a new length of coax directly from the antenna to one TV (run through a window door)? If yes, what were the results?
4. Do you a splitter to support more than one TV. If yes, what is the brand and model number?
If this were a new installation I'd recommend a DB-8e, with the panels facing 20 degrees on a compass and the other 84 degrees. But maybe you what PBS & CBS? They would be much more difficult.
