In my opinion the signal strength at your location requires a DB8e or similar high gain UHF only antenna aimed at Boston. Do not split directions or you may loose the weaker Boston stations. The Lava does not have enough gain to get all the stations that you will want.
To add additional directions do as timgr suggests and add the VHF antenna using the preamp that he suggests.
