Playing around with the map function and putting the icon in different places on Blacksburg and Newport Road (about 10.5 mile NNW from the closest transmitters), I can get hugely different plots just by moving the icon only a little bit. I suggest you run a new plot using the map function (put in the exact address, then zoom in all the way, switch to satellite view, zoom in more if needed, and slide the icon to the exact location of the proposed antenna - don't worry, the TVFool report won't show the exact location, just the resulting plot), and raise the elevation to 25 ft. With all those hills all around, altitude will likely be your friend, and the exact location may generate a much different report.
