Old 9-Oct-2014, 5:33 PM   #5
malachi
Originally Posted by Ben Myers View Post
You can always enter your exact address. If you know your latitude and longitude, enter that instead. If you don't want to enter your exact address, you might consider using just the street name with no number, and the zip code. Please note that the TV Fool report typically doesn't show your street address or exact coordinates.
Sounds like you might. Make sure your connections are tight. Loose connections can easily generate interference or block the signal entirely.
the "map" doesnt show up. im using like an old IE. and a lot of "maps" dont work. not sure if its the plug in the map uses or the old browser they make us use now. wither way it just shows blank.
sweet. on to reseach pre-amps.
malachi is offline   Reply With Quote
