Old 8-Oct-2014, 10:53 PM   #3
BornBlind
Originally Posted by coco View Post
is the rg6 cable old as the antenna? If it is I would try a new balun and new short piece of coax with no splitter. Maybe bring a portable tv outside near antenna mast, the wind may have turned the antenna
Thanks, I have thought about doing this. It mounted so high, I was trying to avoid replacing the cable. This also becomes a challenge at trying to turn the antenna.
I took a tv and hooked it up using about 30 feet of the coax and it produced pretty much the same signal.
One of my concerns was the type of antenna. I am assuming that what I have there is good based off of my report?
BornBlind is offline   Reply With Quote
