This is a condo association, not an HOA with single family homes. The situation may be much more complex and requires an evaluation of information that has not been provided.
There are though, distinctions between "Shared" and "Exclusive" areas.
This is what will mostly determine the permissibility (or lack thereof) of the antenna installation.
I would ignore anything short of a court summons.
That would be ill-advised until the complete situation is known.
Read the FCC OTARD rules, read your associations rules, know your ownership and usage rights, and apply the rules and guidelines appropriately. The small satellite dishes (< 1m) and local OTA antennas (no size limitation) fall under exactly the same provisions of the OTARD rules, so the association cannot make an exception for one device while excluding the other. This is all spelled out in the FCC link above.
