Old 8-Oct-2014, 11:10 AM   #1
RedShoeRider
WLIW New York | It's a stretch, can I reach?
Good Evening, All:
I've been a list lurker for, well, a while. But now, I'm sort of stuck, so I'm sticking my hand up.
The setup right now:
Solid Signal HDB91x antenna on a 4' mast at the peak of the roof (about 35' AGL). Roof is just asphalt shingles over plywood.
There are some trees about 200' in the line of sight toward my target. Neighbors property; I can't do a thing about it.
Feed is RG-6 Quad-shield.
No amplifier - straight into the TV, no splitters.
The signal map: http://www.tvfool.com/?option=com_wr...d24329ac74a363
The problem:
I'm trying, trying, trying to get this station in: WLIW - Channel 21, broadcasting out of Plainview, Long Island, NY. It's 45 miles away as the crow flies.
It doesn't even come up on the signal map for my house, but if I play with the map and go a few towns over to the East, it shows up, albeit weakly. I was using my spec when I was aiming the antenna; couldn't get a thing in the 515mhz area, which is where WLIW transmits. The noise floor was about -95dbm, and I still had zip signal, hence no amplifier yet.
My question:
Before I invest in a much larger, and more expensive, antenna, do I realistically stand a chance of actually getting a solid lock on this station, or am I just asking for too much? I don't have a lot of experience with terrestrial signals, so I figure that someone here is a lot smarter than I am with what I might be able to get away with.
Thanks for any input!
-Chris
RedShoeRider is offline   Reply With Quote
