Old 8-Oct-2014, 12:34 AM   #1
wkndwrnch
7 channels currently
Hi, we would like to improve OTA, reception. looking for advice where to start. Thanks in advance. (Considering raising antenna on roof mount tri pod first)
http://www.tvfool.com/?option=com_wr...d243389cd21940
I have a TERK LOGTVO outdoor antenna,20' high mounted on the roof peak.
RG6 2300 mhz 750 ohm 18 awg 50' from ant. to 1 tv set,no splitter, f connectors,factory installed.
Trees are 40' high,40' to the west, across a busy two lane road,same direction as antenna is focused.
If you have some suggestions,how to improve our reception,cost effective,I would appreciate your ideas. Thanks
Forward Message
wkndwrnch is offline   Reply With Quote
