You require a small to medium high-VHF/UHF combo antenna, not a UHF-only antenna.
Mount the antenna so it has a good view towards Mt Wilson and aim it there. You should not need any amplifiers.
It is quite likely that your dish is located on the wrong side of your roof. If so, it will need to be relocated or replaced.
