Old 6-Oct-2014, 12:16 PM   #16
No static at all
No static at all's Avatar
If you must stay in the attic, the only antenna I would even consider is a 91-XG.
Also, the USB based tuners I have used don't deal with strong signals in the mix as well as conventional TV tuners. Have you tested reception with a regular TV?
Even now, far from strong signals, my USB tuner breaks up much worse/more often than my LCD TV with low flying aircraft anywhere near the house.
