Old 6-Oct-2014, 1:19 AM   #7
StephanieS
A premier option would be an Antennas Direct DB8e with one panel aimed to magnetic 230 with the other being 315.
A lower cost option would be an Antennacraft HBU11k aimed to magnetic 275, splitting the distance between the two towers.
Make sure if you use the HBU11k you have an unobstructed view to magnetic 275. This includes trees and buildings. Both of those elements in play may make a larger antenna needed.
Cheers.
