Follow the instructions that came with the pre-amp for "separate" antennas.
Make absolutely certain that you do not put a power-blocking splitter between the pre-amp and its power inserter.
Make certain the FM Filter is "On" or "In". Do not assume the switches are set as the instructions and markings indicate, verify them.
