The RCA TVPRAMP1R recommended above will mix the signals from the two antennas. Connect the Y10713 to the VHF port and the 91XG to the UHF port. This will give you a single coax lead-in. The preamp mounts on the antenna mast and uses phantom power supplied through the coax cable, from somewhere indoors.
