Hi Jack,
Your local towers are 12 and 14 miles give a nice amount of signal at your location. The majority of those signals as you have already noticed are pretty easy. In regards to if you have chances with the weaker signals. You are right after you nearby cluster of signals, signal options drop dramatically. The US broadcasts are in the category of "extreme measures." You'll notice both PBSs are down below the 0 db strength. This is below "bleeding" edge of digital reception. Unlike old analog broadcasts and getting "snowy", digital over the air signals once they reach a point of certain weakness, they just don't decode. Your access to US signals is below this point of decoding with likely all of the over the shelf antennas and setups. You are into the world of antenna arrays (2 or more hooked up together to create gain) to even attempt the US signals.
I am also getting conflicting information on your Global Network affiliate for Ottawa. Wikipedia reports CIII-DT6 is broadcasting on real channel 14. If that is so, that leaves CIII-TV on real channel 2 a moot point.
It has been said in some cases TV fool's Canadian data isn't as up to date as the US' information.
If you want to feed 3 tvs an indoor antenna may not be able to provide enough signal to those 3 sets. You have a couple options:
1. Keep indoor antenna that doesn't receive the omni and CITY channels. Install a distribution amplifier like the channel master 3414 4 port amp. This operates at the signal split location and provides amplification to offset signal losses.
2. Install Antennas Direct DB8e on your roof free of obstruction and orientate one panel to heading 312 and the other to 181. I'd expect all your local broadcasts to be reliable. Due to excellent signal strength, you can test a 3 way split without amplification and see if the signals are reliable across the 3 tvs. If not, the above CM 3414 may be required.
You'll notice the DB8e is a UHF antenna design.CJOH broadcasts on real channel 13, a high-VHF channel. One thing that is often nice with high-VHF signals that are good to excellent signal strengths is that UHF antennas will often receive them if signal access is really good.
CJOH is strong enough you may not need any supplemental VHF antenna.
Cheers.
