Old 4-Oct-2014, 4:31 PM   #32
tomfoolery
Go to https://www.antennasdirect.com/store...V-Antenna.html and click the Documents tab, then open the Technical Data pdf file, and you can see how the pattern and magnitudes change with changes in the angle between the two panels. Highest forward gain, which is substantial, is with both panels aimed in the same direction.
tomfoolery is offline   Reply With Quote
