Thread: In the Sticks
Old 4-Oct-2014, 3:20 PM   #13
timgr
Originally Posted by BigBean View Post
Can I point the DB8e in two directions to get MeTV? Or do you think the power of all panels
is necessary to pull in just Hartford? I just learned the DB8e panels can be pointed in
multiple directions.
It would be helpful to specify which call sign or real channel you want to add.
That said, all it will cost you to try it is a trip to the roof to change the aim of one of your panels. You could probably do some BOTEC based on the dBm strengths of the subject stations and the change in the sensitivity of the antenna when you reaim the panels... but I expect it's less time and more accurate just to try it.
