Old 3-Oct-2014, 7:44 PM   #2
If you're forced to aim through trees that are within a few hundred feet of the antenna(s), It's hard for me to encourage you to spend the money on a large high gain antenna and preamplifier.
If you have the ability to mount the antenna at a location or height that avoids aiming through trees, the weak signal levels would call for a large combination antenna such as the Winegard HD7698P or... An Antennas Direct DB8E + Antennacraft Y10713.
With either option, I'd expect to need a good preamplifier. I'd consider the Antennas Direct PA-18 and RCA TVPRAMP1R.
