If you attic is not a poor reception location (as many are), you will still be starting at t distinct disadvantage. All attics will reduce signal strength to one degree or another. The only way to know if there is acceptable signal strength and quality in your attic is to try...
I'd suggest an Antennas Direct DB8E facing the main group of signals.
To go after the signal from KEYC, I'd use an Antennacraft Y10713 (if it will fit in the space you have... It's 10 feet long).
An RCA TVPRAMP1R preamplifier has separate inputs for the two antennas (DB8E connects to the UHF input and the Y10713 to the VHF input).
If you can consider outdoor mounting, smaller antennas may provide reliable results.
