Old 3-Oct-2014, 7:20 PM   #9
billg
Assuming you have no trees, buildings, or other obstacles in either signal path:
DB4e with reflectors removed (drill out rivets) plus a VHF1 Retrofit kit mast mounted above the reflector-less DB4e. The result will be a bi-directional UHF/high VHF system that should adequately cover both your markets.
Hi ADTech,
I just received my DB4e and am curious about your statement to remove the reflectors. In the box I see two large pieces: one with the bowties, and one with two square metal grids. The instructions refer to the grids as the reflector, and instruct me to attach the bowties to the reflector using some 5" bolts with aluminum standoffs.
Is your suggestion to simply not use the reflector piece at all, and only mount the bowties? If so, there's nothing to un-rivet, right? I'd simply not connect the bowties to the other piece?
Thanks!
billg is offline   Reply With Quote
