Thread: Need help!
Old 2-Oct-2014, 4:57 PM   #10
tomfoolery
Originally Posted by roundbox52 View Post
If so, what antenna would you suggest as all channels are within a 90 degrees, except 19,20,12 & 22 which are from Canada.
DB8e, with the panels opened only enough, and the pair directed to the SSW only enough to get the three stations you want at magnetic 210-211. Real 23 is going to be tough, and you need all the gain you can get in that direction.
You might get lucky and receive real 19 from Canada off the back, since it's pretty strong and LOS, and you can add a Y10713 aimed at 30 mag. for real 12, even after the fact.
tomfoolery is offline   Reply With Quote
