Old 1-Oct-2014, 10:52 PM   #3
NIS1169
Wow! Thanks for the quick reply and the recommendation. I hadn’t even found that antenna.
I was looking at the Winegard MetroStar MS-2002 Omnidirectional antenna. Just for my own understanding, can you please explain why the HD-1080 would be better for me than the MS-2002? Given you above statement, I’m going to go with your recommendation, I'm just trying to understand the pros and cons vs the MS-2002.
Also, I found Solid Signal makes a version of the HD-1080, the HD1080x. According to their blog (http://forums.signalmarine.com/conte...ignal-antennas!) it is made by Winegard, but the cable connection has been improved. Does anyone have any experience with Solid Signal and are they a good brand, or should I just stick with the original Winegard version?
Thanks again for all the help.
NIS1169 is offline   Reply With Quote
