Thread: Need help!
Old 1-Oct-2014, 4:10 PM   #1
roundbox52
Need help!
I've moved into a new house that doesn't have any cable service and I'd like to keep it that way. I need help with this as I am clueless on the topic and all of the accessories that may be needed with an antenna.
I have a 2 story home with a tall attic. I plan to put the antenna in this attic. The roof construction is asphalt shingles over osb sheathing. Here is the report for this height: http://www.tvfool.com/?option=com_wr...d2436de223fb9a
It also looks like most of the green channels will come in if I put an antenna behind the tv on the first floor, but am unsure if I will need a large antenna or if a small "flat" antenna will work for this height. I have vinyl siding over osb. Here is the report for this height: http://www.tvfool.com/?option=com_wr...d243b217b47502
I will only have 1 H.D. TV.
Thank you in advance for any help.
roundbox52 is offline   Reply With Quote
