Have you tried your Winegard in the attic? I'm not sure what the height difference is, but the extra height could be all you need. Also, are you aimed at WSW now? You should attempt to tune at off angles as well for the sweet spot. The result of this test may save you some money as well as determine the difference between the attic and current location. Use your TV's signal meter to check station strength prior to the attic test. From there, a better antenna decision can be made.
