Old 1-Oct-2014, 11:03 AM   #7
timgr
Also realize that surroundings like trees and buildings and any metal objects or structures can and will change the reception environment. Shielding by trees causes a lot of problems apparently.
One test would be to put your rig in the same location as where your neighbors are getting good reception, and see if you get better results. The implication would be clear.
