Thread: UHF Wire
Old 1-Oct-2014, 5:35 AM   #2
The ideal repair would maintain the same diameter of the conductor as well as the spacing from adjacent parts of the antenna. I would look at crimp barrel type connector (sometimes called butt splice connectors). If the conductor is aluminum, consider using Noalox or a similar anti-oxidant compound to prevent corrosion.
