Old 1-Oct-2014, 1:06 AM   #6
mflynn7
We have 2 different setups:
1) The 'built-in' (passive) setup which uses the Sensar antenna which is mounted to the top of the RV and wired down to the inside of the RV (where we hook up the TV)
2) The 1ByOne (powered) which we mounted to a flagpole. Coax runs from the antenna --> the powered inline adapter --> tv
We've tried each antenna on 3 different TVs. We've had the same results -- the 6 channels I mentioned previously.
You bring up a good point... I am saying my neighbors have the 'same' antenna, (meaning the passive, Sensar) but I'm basing that on 'looks'. I don't know for certain what type they have. Obviously it is powered so that suggests I am wrong.
mflynn7 is offline   Reply With Quote
