Old 30-Sep-2014, 5:25 PM   #1
Radium
Antenna Recommendation for Redmond, WA
I'm planning on switching from cable to OTA but I'm not sure which antenna to buy. Here is my report:
http://www.tvfool.com/?option=com_wr...d243fe9845451f
The only channels I need to receive are the major networks and those all show in green on the chart. I currently have a Winegard FreeVision FV-30BB indoor antenna. I can get most of the channels I want. However Fox (KCPQ) only sometimes works and NBC (KING) doesn't work at all. The other major channels seem to work pretty well.
I'm planning on putting a new antenna in the attic for ease of installation and maintenance. There is also a single row of pine trees that the signal will go through. I'm not sure if the trees make a difference on which antenna to get, but the indoor antenna can receive most channels even with the trees. Which antenna do you recommend for my situation?
Radium is offline   Reply With Quote
