Old 30-Sep-2014, 3:21 PM   #4
timgr
Originally Posted by mikeybass1 View Post
An ambitious system indeed, and a well reviewed antenna. Thanks for the recommendation. So the DB8e has the ability to point the two elements in different directions, thoughts on this scenario with just one DB8e doing the work for UHF signals from both markets?
It's less sensitive with each array pointing in opposite directions. ADTech on here is from Antennas Direct - maybe he can comment. You could buy one and try it, then if the sensitivity is not high enough with the spread arrays, try pointing both the same and see if you can get both markets separately.
