Old 30-Sep-2014, 2:11 PM   #3
mikeybass1
Originally Posted by timgr View Post
An ambitious system would use two Antennas Direct DB8es, widely separated and pointing at 1 and 181.
An ambitious system indeed, and a well reviewed antenna. Thanks for the recommendation. So the DB8e has the ability to point the two elements in different directions, thoughts on this scenario with just one DB8e doing the work for UHF signals from both markets?
You could probably get WMVS Ch 8 PBS with an additional dedicated VHF high antenna like the Antennacraft Y10713 and pick up WLUK ch 11 Fox on the back side. I would skip trying to get weather channel WIWN ch 5 VHF low. The VHF high antenna could be mounted on the same mast as one of the DBes and the signal combined with the UHF.
I'm not worried about trying to get WIWN or WMVS, however I would like to try to get WLUK since it's Fox and they broadcast the majority of Packers games during the season. Again as a failover scenario in case WITI isn't coming in for whatever reason.
mikeybass1 is offline   Reply With Quote
