Old 29-Sep-2014, 9:33 PM   #2
timgr
Originally Posted by mikeybass1 View Post
... Contractors in the area are installing two antennas and combining their signals to receive stations from both markets without having to deal with a rotor. ...
That's what I'd try. An ambitious system would use two Antennas Direct DB8es, widely separated and pointing at 1 and 181. They could be on an A/B switch, or you could use a separate tuner for each with a HTPC to manage program handling. You could probably get WMVS Ch 8 PBS with an additional dedicated VHF high antenna like the Antennacraft Y10713 and pick up WLUK ch 11 Fox on the back side. I would skip trying to get weather channel WIWN ch 5 VHF low. The VHF high antenna could be mounted on the same mast as one of the DBes and the signal combined with the UHF.
