Old 29-Sep-2014, 8:47 PM   #2
Jake V
You have stations in several directions.
For the UHF channels I recommend an Antenns's Driect DB-8e with one panel facing about 2 degrees magnetic (possibly at 330 degrees magnetic if you want Univision and Telemundo) and the other panel facing about 238 degrees.
For the one VHF channel 10 I recommend the Antennacraft Y5713, pointed to 92 degrees magnetic. You might, however, try and see if you can pick this up with the DB-8e as it is a very strong station.
Others will more knowledge than I will also post.
