Old 29-Sep-2014, 8:23 PM   #29
Charles
I'm still looking for some guidance on which coax to use, is RG6 sufficient for what actually would be just under 200 feet or should I go to RG11?
Also, I have the "Antennas Direct , DB8e" and now that I am going to install a rotor, would I get the best results if I aimed both panels in exactly the same direction? That is what I did when I had it mounted on the roof as I was not able to get all of the station from the NE with the panels aimed in different directions. Once I have it mounted on the tower, making adjustments to the separate panels will be a major project.
Charles
Charles is offline   Reply With Quote
