Old 29-Sep-2014, 2:44 PM   #8
Ben Myers
KD3WB
Originally Posted by mdsmith7 View Post
Hello Everyone,
Here is my Signal analysis: http://www.tvfool.com/?option=com_wr...d24349ba85deaa
I need help! I can't get ABC or PBS. I get all the other major netowrks (NBC, FOX, CBS, MyN, CW, ION) and a few others I don't care about.
I have a flat indoor antenna similar to this, but not 100% sure it is this one: http://www.amazon.com/RCA-ANT1050F-U.../ref=pd_cp_e_0
I noticed that PBS and ABC are on different degrees than all the other channels and have therefore moved the antenna around and re-scanned, but to no avail.
Check you television user manual to see if there is a way to add channels manually instead of doing a complete rescan.
The antenna rests on my entertainment center about five feet off the ground. Taping it to the wall hasn't solved the problem either.
Try as many different locations as possible, including the floor.
I'm an 8 min drive from downtown, but I don't think it interferes with my signal nor do I have any really tall buildings near my house.
Other (most likely useless) information:
NBC isn't 10 as indicated on the analysis; it's 4.1.
CBS is on channel 5 (5.1) and 25 (25.1), but I usually, depending upon where I put the antenna, only get one.
Any help is greatly appreciated. I don't think I forgot anything, but if I did let me know. Thanks in advance
Please note that ABC on WKRN in Nashville is transmitting on real channel 27, but will probably show up as channel 2 on your television.
Ben Myers is offline   Reply With Quote
