Old 28-Sep-2014, 6:07 PM   #7
Porkchop2879 has a previous thread:
I lose FOX when I split the signal
http://forum.tvfool.com/showthread.php?t=14896
Originally Posted by Porkchop2879 View Post
I live at Derry rd. and Winston Churchill in Mississauga, Ontario. I have a DB4e, up about 30 feet, which clears the roof line of all the neighboring houses. The run to the splitter is around 40 feet, and then it runs through the house (no idea about the distance from the splitter to the other t.v.s.)
With this set up, I get 22 channels on 3 t.v.s throughout my house using a "left behind Rogers" powered splitter. The splitter says it is zero gain and zero loss. I am extremely happy with how the entire install has gone.
My problem is that with the splitter in the line, I lose WUTV - Fox. If the run goes directly to just one t.v. I get Fox. What can I try to get Fox when the splitter is introduced?
Thanks.
his tvfool report for Derry Rd and Winston Churchill at 20 ft:
http://www.tvfool.com/?option=com_wr...d243e2dc755aa7
at 30 ft:
http://www.tvfool.com/?option=com_wr...d243b220746a80
adjacent channel interference from CH15?
What happens when you aim your antenna directly at FOX, 142 degrees magnetic?
Replace Rogers zero-gain splitter with a Channel Master 3412 distribution amp. You just need a little more gain in your distribution system.
I am thinking the length of cable to each house t.v. is now the issue as to why each t.v. is getting different channels?
I agree. Also, different TVs have different tuner sensitivity.
Connect the TV with the longest coax run to one output of the CM3412. Connect a 2-way passive splitter to the other output of the CM3412 to feed the other 2 TVs that have shorter coax runs.
No preamp at the antenna for this test.
For 4 TVs, use a CM3414 and no passive splitter. However, it has less gain than the 3412 with 2-way splitter as above for the longest run; 8 dB VS 11.5 dB.
Please let us know how it works out. Don't start a new thread, use this one. It confuses us when you start a new thread for the same topic.
