Old 28-Sep-2014, 3:10 PM   #6
Ben Myers
KD3WB
Originally Posted by Porkchop2879 View Post
I have a DB4e up on my roof. I was getting 22 channels with a zero gain (powered) splitter that was left here by Rogers. All I wanted to do was boost my signal so I could pick up WUTV Fox. So I bought a Pre-amp and passive splitter. I connected everything and now I only get 9 channels.
Restore the original configuration and see if the channels return. If they do, try raising or lowering the antenna and see if Fox comes in. Also, make sure the antenna is aimed properly.
The only thing I can think of is that up at the antenna, a short cable from the antenna to the pre-amp is now cutting across the front of a section of the antenna. Might this be the problem?
Reroute the cable so it isn't blocking the signal. Also, as mentioned by another poster, not all splitters will pass the DC voltage needed to power a preamp and many of those that do will also pass it to the other device or devices to which the splitter is connected.
Ben Myers is offline   Reply With Quote
